67 Users Online (66 Members):
Forums >> Revit Building >> Technical Support >> Revit2013 - 'Pipe Size' Parameter Can't Be Used
23 Posts No Rating |
Hey gang, I posted this over on AUGI but was hopign someone here might be smarter and/or quicker. I've got a family that I need to add a "cold water connection size" parameter to but am having a problem. We have all of these parameters in a file, so it's just a simple issue of adding the right one. But when I choose any "Pipe Size" parameter I get a message of "Parameter Type 'Pipe Size' Cannot Be Used". Any idea what is going on here?
What category is the family? Where does it sort out in your browser?
It is a Specialty Equipment category family. Like I said, we have these parameters pre-edited and held in a file for quick loading, and we've loaded this same parameter to other families of the same category type without issue.
I don't do MEP but if that is a system parameter, it may not be usable in that family category.
''Visibility grafics'' and ''create parts'' problem when mak |
Fri, Mar 19, 2021 at 11:45:46 AM
Changing paramaters of 'Title with line' |
Wed, Sep 20, 2006 at 9:47:18 PM
Add ''scale'' on a drawing list, when it is not under ''available fiel |
Thu, Jan 12, 2012 at 8:35:32 AM
'Out of Memory' pop up |
Tue, Sep 6, 2005 at 3:16:07 PM
I can't change the connecor size. It stays on -609.6 mm |
Mon, May 18, 2015 at 7:06:40 AM
Members: | 2016919 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
