87 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Post and beam house
Thu, Jun 6, 2013 at 10:17:32 PM | Post and beam house
Javadevil
Hi there,
I'm just starting to learn revit and am having trouble creating a simple post and beam house.
The main thing thats slowing me down is;  windows and doors do not recognise a "component in place" post I've made, architectural columns or Structural columns.  So theres no way to put in windows and doors between posts.
I've tried other ways, creating a wall, insert window, but I cannot insert a post/column in the wall.
the post and wall just sit ontop of one another.
That doesn't help either as I still cannot put a sliding door up against a post
I'm sure theres way.
Fri, Jun 7, 2013 at 7:29:42 AM | Post and beam house
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I am not following your problem.  "windows and doors do not recognise a "component in place" post I've made" What did you make? What do you mean they aren't recognizing them?  You can create a wall and then create a column or "post" at the ends of the wall.  A column will cut a wall.
Fri, Jun 7, 2013 at 8:23:08 PM | Post and beam house
Javadevil
Hi Teafoe,
Thanks Teafoe,
I figure out whats going on. I have to create wall first --> place a column--> put in door.
With out a wall a door will not recognise a column so you cannot put a window in the scene.
cheers
CHANGING A BEAM(S) WORKPLANE
Tue, Jan 25, 2005 at 1:00:15 PM
MIRROR entire HOUSE
Thu, Feb 12, 2009 at 6:23:19 AM
Meeting Beam Systems to Glulam Beam
Wed, Jun 20, 2012 at 10:34:16 AM
Structural beam won't show in elevation
Fri, Aug 12, 2005 at 5:22:08 PM
RFA of a green house or hoop house
Tue, Jul 28, 2015 at 12:53:14 PM
Page generation time: 0.5305
