51 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> Not able to import families through load family..no error msg.jury tomo!!
6 Posts No Rating |
Hi guys...i got jury tomorrow! i need to finish my work today so please help..i am a beginner in revit.I am trying to load family to insert columns and other furniture.But after i click load family and select the tree or the column i need to insert, nothing happens..nothing at al..the screen is just like before. But i tried inserting a column first time and it worked..only that once...never again! help..
Hi RevitH,
Try this.
In your Project Browser, go to "Families", under "Columns" you can see for example "Rectangular Column", which is the Family, under it there are "18"x18", "24"x24",...., they are types, just select 18"x18" and drag to the plan, that's the easiest way for the time being. You can learn other ways later.
Edited on: Thu, Jun 6, 2013 at 9:17:21 PM
6 Posts No Rating |
I tried tat! but i need a round column badly cos its visible and has to be roundits not just this file but all revit files and i need to ut plant and furniture too! not just column...how to make this work...
and wen i click render, It gives error message, 'there was some problem and revit could not render' and hangs and closes down...i have a bad feeling Help
Revit 2010 and Revit 2009 families error |
Mon, Sep 21, 2009 at 1:35:48 PM
The family is not of the correct category |
Sat, Feb 19, 2011 at 5:49:59 PM
A fatal error loading family into project overwriting existing |
Mon, Jun 22, 2015 at 8:03:38 AM
family dont Load!! |
Sat, Apr 18, 2015 at 9:22:41 AM
Corrupt Dwg? - Can't load families [ 1 2 ] |
Thu, Jul 16, 2015 at 10:55:31 AM
17
Members: | 2017200 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
