81 Users Online (80 Members):
Forums >> Revit Building >> Technical Support >> Curved Rail Problem
Hi,
I have this curved stair which is giving me headaches at several areas. I'm using rather simple profiles for the handrail and for the corner moulding running along the bottom of stair (I did that as a railing and offset it). The problem as you can see is when the profile begins to curve it looks weird. Any thoughts on how to remedy this would be greatly appreciated.
Thanks,
Robie
![dingohot Avatar](user_avatar/155924.jpg)
![3.5 Stars: 5 Votes](/images/stars_3.5.gif) |
it's natural.
you have to make angle of curved part and straight part same to make joint smooth, but it's impossible at all.
because, slope angles of each inside and ouside edges are not same in cureved rail.
if you change the profile to round one(not rectangle) then you can get better result i guess.
want more?
You can get more tips at Enjoy Revit |
rail termination |
Tue, Apr 8, 2014 at 10:18:59 AM
Set baluster on Bottom Rail |
Thu, Mar 29, 2012 at 8:59:47 AM
Double curved railing |
Fri, Mar 2, 2007 at 7:58:14 PM
Top rail offset |
Wed, Jun 21, 2017 at 11:14:51 AM
stair railing baluster properties not consistant with deck rail |
Wed, Sep 3, 2008 at 11:08:32 AM
Members: | 2022438 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
