90 Users Online (89 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Replace blank curtain wall panel
Thu, Jun 6, 2013 at 3:25:26 AM | Replace blank curtain wall panel
archie456
3 Stars: 1 Votes
Hi,
I'm editting a curtain wall panel which I didn't create. Some how some of the panels have been deleted and replaced with nothing.
See the attached image which shows the wall sectioned, you'll see that the top row has glazing in the middle and the panels to the left and right are missing.
I need to replace these empty panels with glass - but I can't because there is nothign to select and so I cant change the type.
I tried changing Curtain Panel in the type from None to System Panel: Glazed - but that didn't change the emply panels.
Where am I going wrong?
Cheers.
Thu, Jun 6, 2013 at 3:31:40 AM | Replace blank curtain wall panel
archie456
3 Stars: 1 Votes
OK, I'm being a complete idiot.
The reason the panels were blank was because when you pick the wall to isolate it, Revit doesn't select any panels which have been changed to windows, and so they are not isolated.
I'll go for a cup of coffee, that will help.
Thu, Jun 6, 2013 at 7:11:12 AM | Replace blank curtain wall panel
Revit also has a default "empty system panel".
Mon, Oct 12, 2015 at 11:31:47 AM | Replace blank curtain wall panel
andy777bennett
so if I have a large wall with system pannel empty as the default and wanted to change some to solid panels, how could I select the empty ones?
Mon, Oct 12, 2015 at 12:06:22 PM | Replace blank curtain wall panel
Hello.... do you try?
Mon, Oct 12, 2015 at 12:06:40 PM | Replace blank curtain wall panel
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
You can still select an empty panel – use tab key, or window select panels and mullions and use filter tool to get panels only.
Mon, Oct 12, 2015 at 12:13:57 PM | Replace blank curtain wall panel
andy777bennett
Forgot about the filter. I couldn't get it to work tabbing. my mullions are 1'x1' so finding where the pannel would be was confusing. Thanks
Cannot replace panels in a Curtain Wall, then copy
Mon, Apr 12, 2010 at 1:37:21 PM
customerized curtain panel doesn't work with the irreglar shaped panel?
Sat, Jul 10, 2010 at 1:48:43 PM
curtain wall panel
Sun, Mar 13, 2005 at 11:14:53 AM
Family in Project Browser, but not in project 2014
Sat, Sep 21, 2013 at 3:08:09 PM
Curtain Wall Panel to Curtain Wall Door
Mon, Jun 23, 2014 at 9:32:12 AM
Page generation time: 0.7721
