39 Users Online (38 Members):
Forums >> Community >> Newbies >> Linked CAD and Scaling
I have a site plan and some buildings. I linked all of the buildings from CAD. Each is in it's own Revit file. I scaled teh site plan in CAD and linked it to Revit. For some reason when the site plan came over it wasn't scaled properly. I tried again and the same thing. What is different between the two and how do i fix it?
Did you reload the link or re-open the Revit file after changing the linked file?
Revit only loads the file on start-up or when you tell it to.
I unloaded it in manage links and reloaded it from CAD. I went into my CAd files and brought a building into the site drawing and it fits in perfectly. It is getting messed up somewhere in the linking process.
I think this is a process error. I don't know what you mean by you scaled the CAD file. Do you mean it was drawn incorrectly? Scale doesn't rally matter - physical size does.
The file is linked to Revit using a scale factor. Make sure that is correct.
i had to make the units the same in Revit as what they were in AutoCAD. I had it set to auto detect but for some reason that didn't work so i made them both inches and Presto.
Thanks WWHub
Constraining to linked CAD file |
Thu, Apr 4, 2013 at 3:09:14 AM
Export from Revit To CAD with RELATIVE linked files |
Wed, Nov 29, 2017 at 11:00:35 AM
revit freezing and not responding when cad file linked |
Fri, Feb 6, 2015 at 11:24:56 AM
Problem exporting view with linked CAD file |
Wed, Mar 18, 2009 at 3:46:34 PM
Linked CAD files are not turning off |
Tue, Nov 29, 2016 at 3:31:28 PM
14
Members: | 2017233 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
