68 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Changing material of one element changes all materials
Sun, Jun 2, 2013 at 2:41:25 PM | Changing material of one element changes all materials
Wolfishfish
Hello! I have a small problem with my materials. The thing is when I change the material for one element automatically it affects another. For example I set my floor finish as white marble. Then I create a model in place as a furniture and set its material as a red plastic. So I start rendering and my furniture and my floor finish become red plastic. So it seems to me which material was added the last is the one which appears on rendering...
Another example: I created a railing, and set the materials as blue glass. Then I created a tube which I set as green glass..When I render evrth becomes green glass..Pls help.
P.S. When I select the material revit asks replace or keep both, I always select "kepp both" but stil...
Sun, Jun 2, 2013 at 5:22:53 PM | Changing material of one element changes all materials
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I would assume you are not duplicating and changing the material in the correct spot so your process is most likely wrong. What version of revit are you using
Sun, Jun 2, 2013 at 11:13:38 PM | Changing material of one element changes all materials
Wolfishfish
Revit 2012. I guess the process is wrong. I normally duplicate, but when it comes to models in place I didn't see "duplicate" option.
Changing materials
Fri, Oct 4, 2013 at 10:18:57 AM
family element render materials [ 1 2 ]
Sat, Feb 14, 2009 at 10:47:02 AM
17
How do you to tell the difference between Element, User and Material Keynotes?
Tue, Aug 17, 2010 at 4:48:32 PM
Making Element, User and Material Keynotes look different
Fri, Jan 8, 2016 at 5:59:45 PM
Keeping an Element Keynote from changing?
Mon, Apr 15, 2013 at 12:14:44 PM
Page generation time: 1.3620
