107 Users Online (109 Members):
Forums >> Revit Building >> Technical Support >> Members of the truss are not visible after rendering
12 Posts No Rating |
Hello and good day. My problem is: I am using DLH-series bar joists as a structural trus. It is visible in 3d, sections, any view before rendring, but when I render the members of the truss dissappear and u can only see top and bottom horizontal members without the web.
Attaching the image below. U can see that c-channels are visible but the lower trusses are not. Pls help
Try changing your detail level to fine
oh, so simple, but it works! I was trying to edit type and things like that. Thank you very much!
Revit 2012 Truss System (framing members not showing) |
Wed, May 9, 2012 at 9:25:33 AM
Truss - coping frame members |
Mon, Aug 16, 2010 at 5:51:35 AM
structural truss element not visible in section |
Sun, Jun 28, 2020 at 7:05:03 AM
truss not visible on framing plan |
Mon, Apr 27, 2009 at 4:28:30 PM
Beam system members invisible in all views |
Fri, Mar 25, 2022 at 5:50:55 AM
Members: | 2056367 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
