103 Users Online (102 Members):
Forums >> Revit Building >> Technical Support >> Converting associated levels to non plan view level
4 Posts No Rating |
Hi,
I have accidently created some associated levels with view plans, which I don't need to appear in my project browser under floor plans and so on. Is there a way to chage them to non assoiated levels (so that you have a black level head instead of the blue one) so that I don't see them anymore.
Thank you!
Hamed Torakai
A level will show up in views no matter if it has associated plans or not. We often have levels that don't have plans .... like Top of Wall (Parapet)... Top of Steel .... or other references.
To make a level black (no reason to do this) - delete the associated plan view. Hide the level if you don't want to see it.
![coreed Avatar](user_avatar/14568.jpg)
Hi,
Thank you!
Hamed Torakai
https://chronicle.autodesk.com/Main/Details/2c1913aa-3615-413b-8cd8-74376c7f01da
4 Posts No Rating |
Thnx Coreed,
This is exactly what I wanted.
Hamd Torakai
Thnx Coreed,
Hamd Torakai
Your Welcome
Plan view levels |
Tue, May 5, 2009 at 3:15:03 PM
Select All Objects by Referenced Level? |
Mon, Jun 5, 2006 at 5:14:28 PM
Placing Electrical on Walls of different levels that are in same view |
Thu, Mar 5, 2015 at 9:41:25 AM
view depth without dims |
Thu, Jan 15, 2009 at 11:27:04 AM
Full edit capabilities insiide plan region |
Thu, Dec 8, 2005 at 4:13:57 AM
Members: | 2017035 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
