72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Section box which is not rectangular
Wed, May 29, 2013 at 7:01:28 PM | Section box which is not rectangular
danezeq
is there any option to make section form which isn't rectangular in revit?
Wed, May 29, 2013 at 7:37:15 PM | Section box which is not rectangular
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
it's impossible as i know, but you can just rotate section box.
want more?
You can get more tips at Enjoy Revit
Wed, May 29, 2013 at 7:42:37 PM | Section box which is not rectangular
danezeq
THank you again for your answer. I hope it'll be possible in the future.
Rotating a section box is very slowly and climzy.
And anyway i need complex section form to make 3-d COMPLEX sections (sections which are not stem from straight line)
Thu, May 30, 2013 at 12:55:52 AM | Section box which is not rectangular
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Do multiple sections of the same section, overlay them all in one view and then reduce the view box in each of them to make up your profile section.
Thu, May 30, 2013 at 3:20:02 AM | Section box which is not rectangular
danezeq
Sorry i red it few times and can't understand.
i will keep try
Thu, May 30, 2013 at 3:39:53 AM | danezeq
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Quoting danezeq from 2013-05-30 03:20:01
i will keep try
i think he's talking about combining views. make few differnt section views at same view point and combine them at one sheet.. it makes sence.. and possible unless very complecated section.
want more?
Thu, May 30, 2013 at 3:43:17 AM | Section box which is not rectangular
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
and here's a sample i just made for you...Smile
want more?
Thu, May 30, 2013 at 3:55:58 AM | Section box which is not rectangular
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Yep - spot on
Mon, Jun 3, 2013 at 9:30:44 AM | Section box which is not rectangular
danezeq
is it HAS to be done using SHEET only?
i still dont get it how shuld it be done.
Mon, Jun 3, 2013 at 7:55:51 PM | Section box which is not rectangular
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
It cannot be done the way you want. Im sorry.
Mon, Jun 24, 2013 at 7:55:20 PM | danezeq
#11
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Quoting danezeq from 2013-06-03 09:30:43
watch this
http://youtu.be/2DW-DfF7bjw
want more?
Mon, Jun 24, 2013 at 8:15:55 PM | Section box which is not rectangular
#12
danezeq
thank you
my problem is the the intended complex section is designated for RENDER - and rendering a sheet isn't possible.
what is more, the disired section is more complex and perspective so i tried your trick and it look like 3 copy-pasted sections while the transition between them is un natural.
ican upload en example here.
Section box in Section??
Sat, Dec 10, 2011 at 10:23:02 PM
13
Problem with a rectangular section on a adaptive arch
Sun, May 19, 2013 at 2:05:23 AM
3D Section Box
Thu, Nov 1, 2012 at 11:00:41 AM
"True" Shadows in Section Box (Section Perspective?)
Tue, Nov 15, 2011 at 6:02:22 PM
Attach Building Section Heads to Section Box
Mon, Sep 21, 2015 at 4:53:58 PM
Page generation time: 0.4641
