Forums >> Revit Building >> Technical Support >> How to Load Multiple Families into Revit Project File in 1 Shot
32 Posts No Rating |
Does anybody know how to load multiple families into Revit Project File in 1 shot (ie together) without having to open each individual familiy in order to load?
I want to try to avoid copying families as Revit creates duplicates when I try to do that.
FYI, my existing families are in a project template file.
USING REVIT ARCHITECTURE 2013 |
Hi Yilin,
The way I did was, place the families in one project, for example 5 door families, then copy and paste onto another project at once. Is that what are you looking for?
Edited on: Tue, May 28, 2013 at 6:41:11 PM
Hi David,
Thank you for your suggestion. I was trying to avoid doing that, as sometimes Revit tends to duplicate existing families that have the same name. I was hoping there was a command in Revit that can allow me to import/load families all at once without having to do the copy short cut but I guess that is wishful thinking :p
Hi Yiling,
"Revit tends to duplicate existing families that have the same name", did you mean that
Famiies......
....... Doors
..........Single-Flush
...........Single-Flush ?
I always change the second "Single-Flush" with the size of the door like "36"x 82""; the first "Single-Flash" is the name of the family, the second "Single-Flash" which I changed to "36"x84"" is the Type. I think that you should always rename it. They are several reasons to do so, firstly, the "Type" is a very useful field, which can be shown in schedules, secondly, when you are using copy and paste as in previous thread, the "36"x84"" door will bring in both "Single-Flash" family, and "36"x84"" type into new project. To me, it is a good practice to spend extra couple seconds to re-name the type, which can help you organize your project better.
cannot load families into my project |
Tue, Aug 15, 2006 at 2:20:21 PM
Cannot load families into project |
Wed, Apr 11, 2012 at 7:50:23 PM
Corrupt Dwg? - Can't load families [ 1 2 ] |
Thu, Jul 16, 2015 at 10:55:31 AM
17
I cannot load families into my project! AHH |
Tue, May 10, 2011 at 6:05:26 PM
Revit 2016 and 2017 Insert View From File Interface |
Tue, May 24, 2016 at 1:35:37 PM
Members: | 2098909 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
