62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> In shaded View walls/roofs are showing material and lines behind them
Tue, May 28, 2013 at 9:17:52 AM | In shaded View walls/roofs are showing material and lines behind them
joshuabenway
I'm trying to do a simple rendering for a client but for some reason where the roof is showing the chimney material where it passes infront of it. Its also showing some lines behind it where the walls are. Is there a setting that i have set thats allowing this to happen?
I attached an image of what the issue looks like. It happens with some walls showing some lines of objects in the room too.
Thanks
Tue, May 28, 2013 at 9:35:45 AM | In shaded View walls/roofs are showing material and lines behind them
This may be a graphics card issue.
Make sure you have the latest Revit build, the latest drivers and you may want to switch off hardware acceleration - under the revit R pulldown / options.
Material not showing up in shaded view.
Mon, May 6, 2013 at 5:19:19 PM
Wireframe lines showing up in Shaded 3D View
Thu, Apr 2, 2009 at 11:36:36 AM
Topo material color not showing?
Thu, Nov 26, 2020 at 11:24:42 AM
2013 Wire Frame Showing in Shaded Mode
Thu, Apr 25, 2013 at 7:06:57 AM
Demolition with Shaded Visual Style Revit 2014
Mon, Apr 28, 2014 at 5:46:31 PM
Page generation time: 3.2070
