135 Users Online (134 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Multiple Floor Plans
Tue, May 28, 2013 at 8:58:15 AM | Multiple Floor Plans
LissHunter
1 Stars: 1 Votes
I have one large area of land that i am putting nine different buildings on. i would like each building to go on it's own plan view. is there a way i can do this and not have the other buildings show up on each others view? i would like to keep tehm all at an offset of 0 because i will have one drawing with all the buildings laid out.
Tue, May 28, 2013 at 9:10:25 AM | Multiple Floor Plans
3.5 Stars: 396 Votes
Is this a view question or a level question?You can make as many plas as you want and you can control the view limits of each plan.
You can only have one "Level One" But you can have "Level 1A", "Level 1B".... so evel if the levels are not at the same geographical level, they can be named similar.
If all of the buildings are in one file, then you need to at least use worksets to manage the model components.
A better option is to document your buildings in seperate files and link them together as appropriate for overall site.
Multiple sheets from same floor plan view with different scales?
Fri, Aug 1, 2008 at 12:01:43 PM
Sheet layouts for multiple floors?
Sun, Nov 13, 2005 at 5:59:13 PM
Enlarge Floor Plans
Thu, Feb 12, 2009 at 4:12:21 PM
12
Best Software to Create Presentation Floor Plans
Fri, Apr 30, 2010 at 12:56:47 AM
Using Area Plans as Main Floor and Unit Layout plans
Mon, Mar 29, 2021 at 1:59:33 PM
Page generation time: 2.8007
