51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> site orientation
Mon, Feb 6, 2006 at 9:08:56 AM | site orientation
scathendo
i've drawn the property lines using the table (they are labeled per 'true north'.and now i need to rotate the site to fit my drawing sheets (project north). i only see a tool to rotate the true north rotation. what i need is a project north rotation that let's me orient the project for documentation without screwing up my site bearing tags. does anyone know how to do this? i've tried..... setting the viewport to true north, rotating the project to the orientation i need and then using the rotate true north command to rotate it back. the north arrow symbol rotates correctly but the property line bearings still show the incorrect bearing? Post edited on 2006-02-06 09:14:07
Sun, Feb 17, 2008 at 8:15:46 PM | site orientation
vanostran
vanostran Avatar
3 Stars: 2 Votes
I have a similar problem. I can rotate the project on my sheet, but then the title rotates with it. Do you have any idea how to rotate the drawing on the sheet and keep the title in the same position? thanks
Mon, Feb 18, 2008 at 1:35:35 AM | site orientation
eldados
eldados Avatar
4.5 Stars: 8 Votes
scanhendo:
no easy way here, but you will need to rotate your whole project to project north, redo your boundary (you can always export to DWG and import back into your drawings and use the Pick when doing your boundaries again...  than rotate to true north
Vanostran:
you don't have the same problem Smile you are rotating your view on the sheet. I know of no way to rotate just the title...
Integrator
KarelCAD
Site Orientation
Fri, Jul 1, 2005 at 3:52:38 PM
Building Orientation on a site
Thu, Feb 15, 2007 at 10:07:42 AM
Linked Revit model not importing in the correct orientation
Fri, Nov 20, 2015 at 4:00:35 AM
3D View orientation won't lock
Sun, Feb 26, 2012 at 7:44:07 PM
add orientation to window schedule
Mon, Feb 3, 2014 at 7:23:49 AM
Page generation time: 0.4667
