73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Showing column cut on top of wall cut pattern
Sat, May 25, 2013 at 6:15:48 PM | Showing column cut on top of wall cut pattern
OmarMok
Hey everyone,
I have a fairly simple problem: I'd like to shows the cut pattern of my columns on top of my wall (on is in black solid hatch and the other is in grey solid hatch). So far I have tried: "Override Graphic in View" and editing the properties of the family itself with no success.
Thank you all for any help
Cheers
Mon, May 27, 2013 at 7:32:30 AM | Showing column cut on top of wall cut pattern
Bayonle
I don't really understand your question. Is the wall cutting through your column????. If so then join the column to the wall. The column then automatically cuts through the wall.
Mon, May 27, 2013 at 7:33:11 AM | Showing column cut on top of wall cut pattern
Bayonle
You can send a drawing showing me your problem.
Mon, May 27, 2013 at 6:10:31 PM | Showing column cut on top of wall cut pattern
OmarMok
Hey
I attached a picture showing the problem I'm facing. I'd like for the entire cut of the column to show "on top" of the cut of the wall.
Thanks for any help
Cheers
Tue, May 28, 2013 at 1:37:20 AM | Showing column cut on top of wall cut pattern
Bayonle
There are two things you can do to solve this problem. You can either split (SL) the wall into the parts and delete the middle portion or join the column to the wall. I prefer the second option. The join tool can be found in the modify tab. Hope this help you.
Bye
Tue, May 28, 2013 at 4:06:06 AM | Showing column cut on top of wall cut pattern
OmarMok
Hey
Thanks for any help
Cheers
ARCHITECTURAL COLUMN ISSUE
Thu, Feb 13, 2014 at 8:50:51 PM
loss of cut pattern
Fri, Nov 28, 2014 at 8:47:11 AM
5'8" wall will not be cut by cutplane
Mon, Nov 13, 2017 at 3:50:00 PM
Plan view not showing cut wall
Tue, Sep 22, 2015 at 8:08:15 AM
How Do I Cut Out Part Of The Wall?
Wed, Apr 22, 2009 at 5:30:19 PM
Page generation time: 1.2809
