Forums >> Revit Systems >> Technical Support >> Duct Loss Coefficient not matching
Fri, May 24, 2013 at 2:13:46 PM | Duct Loss Coefficient not matching
bxuser
Hello
I have a 100 ft duct with 3600 cfm. The duct is 24 in. in Dia. I'm trying to find the Loss Coefficient.
Revit 2013 gives me a value of .821083.
I hand calculated the value based on the Altshul-Tsal friction factor equation . The number I came up with
was .016323.
Re-236450.6, Dh-24, E-.0003,
Why the difference in numbers?
Thanks
Thu, May 30, 2013 at 11:29:07 AM | Duct Loss Coefficient not matching
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are you sure your calculations are correct?
Sat, Jun 1, 2013 at 10:41:33 AM | Duct Loss Coefficient not matching
bxuser
Yes. Checked and rechecked
duct static pressure loss
Mon, Aug 15, 2011 at 2:18:11 PM
ASHRAE TBL files and pressure loss calculation in Revit MEP 2012
Sun, Sep 4, 2011 at 4:32:06 PM
Capping a Duct
Tue, Jan 21, 2014 at 9:46:17 AM
Duct pressure loss calculation
Tue, Sep 29, 2015 at 3:32:05 AM
Duct Fitting Issue
Tue, Apr 1, 2014 at 1:16:35 PM
Page generation time: 0.7255
