57 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> large scale projects in REVIT
Fri, May 24, 2013 at 10:35:17 AM | large scale projects in REVIT
danezeq
Hello everyone.
My project are always large scaled dealing the city.
that's why my project always very slow on revit.
sometime it's just loading for ever and i need to restart revit.
Neverthe less i LOVE revit. i can do my planning only with revit.
what would you suggest tom me?
is there anyway to make things faster with revit for me?
My computer:
Motheboard:Manufacturer Gigabyte Technology Co., Ltd.Model X58A-UD3RNorth Bridge Intel X58 Revision 13South Bridge Intel 82801JR (ICH10R) Revision 00CPU:Name Intel(R) Core(TM) i7 CPU 950 @ 3.07GHzCpu Socket Socket 1366 LGAMax CPU Speed 4000MHz
RAM:DDR3Installed Memory 18432 MBytesChannels 3
Video Adapter NVIDIA GeForce GTS 450Video Processor GeForce GTS 450Technology 40 nmAdapter DAC Type Integrated RAMDACMemory 1024 MBytesDedicated Video Memory 978 MB (1025966080)Dedicated System Memory 0 MB (0)Shared System Memory 3071 MB (322110668Shadey
Fri, May 24, 2013 at 10:39:49 AM | large scale projects in REVIT
danezeq
i captured my project...
http://www.youtube.com/watch?v=FxHlLTebkR4
Fri, May 24, 2013 at 10:52:33 AM | large scale projects in REVIT
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I would make sure of linking and worksets for a project like this.  I wouldn't have everything in one file as that will be way to big so split it up in a way that makes sense to the project..  I would also use hidden line for my visual style unless absolutly necessary as realistic will really slow it down also.
I'm not really big into computer components and not sure how yours compares to this or if you are looking to upgrade (not cheap) this is a system that looks amazing.
http://config.boxxtech.com/solutions/revit_solution.asp
Fri, May 24, 2013 at 10:56:59 AM | large scale projects in REVIT
  1. Learn to use worksets.  Have different areas of that model in different worksets then only load the worksets you need at the time you are working.  You can do a reduced load at startup and modify anytime.
  2. Always save your project from a single, simple view.  NO TILED VIEWPORTS!
  3. Turn off shading and shadows.  Only turn them on when you need them.
Fri, May 24, 2013 at 2:34:04 PM | large scale projects in REVIT
danezeq
thank you
about the workset (which is new for me)
i divided my project to different worksets.
and now what?
When i open the file it loads all the workset.
how can load only one workset?
Fri, May 24, 2013 at 2:49:41 PM | large scale projects in REVIT
danezeq
and another thing
it's impossible to take part of the model and move it to another workset  AT ONCE (one selection) like in this video
http://www.youtube.com/watch?v=wVT74tW2zn0 Cryinggo to 5:30)
beacuse when i pick elements that include wall mullions - it not letting me change the workset (the line WORKSET is getting grey at properties window)
Fri, May 24, 2013 at 4:05:07 PM | large scale projects in REVIT
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I dont think you understand worksets. Look in your HELP for an explination. Worksets are always in the project but you can turn them on and off as you need
Fri, May 24, 2013 at 4:19:46 PM | large scale projects in REVIT
danezeq
Yes i understand that, but WWHub gave me the idea of using worksets to load just the relevant part of the project each time while leave the irlevant unloaded.
Sat, May 25, 2013 at 9:34:53 AM | large scale projects in REVIT
Yes, you can load/unload worksets.
When you go to open your project, there is an option pulldown.  There you can load worsets as last used or specify.   This is the reduced load.
While in the project, you can go to the collaborate/worksets tab and you will find a pulldown there.  You can load/unload worksets here.
Sat, May 25, 2013 at 9:40:14 AM | large scale projects in REVIT
danezeq
Thank you very much i just discovered that pulldown 5 min ago! thank you
so there's no need to save a file for every workset - it doesnot work that way right?
you just save a central file with include the all worksets inside.
and as i work alone on this project - i don't need to creatve local files EVER, just use the central file regularly.
did i get it right?
thank you again!
Sat, May 25, 2013 at 9:54:58 AM | large scale projects in REVIT
#11
danezeq
Just a sec..
i have a problem understanding how it works.
1. How can i know i work on the central file? if the icon "save" is grey (disabled) then i'm on the central file?
2. i cannot just SAVE, only SAVE AS! i used to press CTRL+S every few min - and it doesn't save! i lost an hour of work - twice!
Sat, May 25, 2013 at 1:28:16 PM | large scale projects in REVIT
#12
You need to read your HELP on work sharing or you will never get to where you need to be.
READ IT - then come back if you have problems.
Large scale projects with repeating rooms grouped...
Wed, Jul 25, 2007 at 8:48:43 AM
Complex Healthcare Projects - Can Revit do their equipment schedules too?
Thu, Nov 20, 2014 at 2:59:39 PM
Annotations too large
Wed, Jun 2, 2010 at 8:37:41 AM
File Management - Large Projects
Mon, Nov 14, 2016 at 10:46:42 AM
the large projects are not to be solved by (Soft) solution
Mon, Dec 30, 2013 at 8:44:11 AM
Page generation time: 3.3395
