Forums >> Revit Building >> Tips & Tricks >> Additional Raised Seam Roof (Sloped Glaziing) Trick
Sun, Feb 5, 2006 at 4:27:34 PM | Additional Raised Seam Roof (Sloped Glaziing) Trick
Formfunction33
I found a trick that helps to make Raised Seam rooves...using the mullion technique found inn ealrier threads.....but what i did was: 1. copy the roof (or rooves) onto themselves, so that there are two rooves hidden in one. 2. Select one roof and change it to Sloped Glazing 3. then edit the properties - chaneg System Panel =s Empty", this makes the glass diappear. 3. Then go and edit the mullions by selecting, make your seam size. 4. In elevation view move the glazing edge up to match the ridge of roof The seam will poke up, but there will be no glass. Post edited on 2006-02-05 16:35:43
Wed, Feb 20, 2008 at 10:39:21 AM | Additional Raised Seam Roof (Sloped Glaziing) Trick
twhisker
2.5 Stars: 5 Votes
I am trying to get an arched roof with a stadning seam roof.  Sloped glazing works well on the sloped roofs, but the arched roof causes it to have multiple horizontal lines in order to form the curve.  It would work perfectly if I was able to do it without the panel and just the mullion.
How to you make system panel = s_empty as mentioned above?
Revit Architecture 2010
Wed, Feb 20, 2008 at 12:32:34 PM | Additional Raised Seam Roof (Sloped Glaziing) Trick
3.5 Stars: 400 Votes
On an arched roof that I did, I did my standing seam battons as a seperate element and arrayed them.
Sloped glazing roof grid layouts
Wed, May 23, 2007 at 10:32:50 AM
arched standing seam metal roof
Mon, Feb 19, 2007 at 5:42:41 PM
Standing Seam Metal Roof help [ 1 2 ]
Mon, Sep 28, 2009 at 1:54:10 PM
15
Opening in Generic Model Standing seam roof
Mon, Aug 17, 2009 at 9:43:32 AM
Standing Seam Problem
Sun, May 1, 2011 at 1:39:07 PM
Page generation time: 0.5049
