91 Users Online (90 Members):
Forums >> Revit Building >> Technical Support >> walls in section
1 Posts No Rating |
Hi All
Is there a way I can get the wall cladding to show correctly in Section ?
When I have a wall with claddingon the exterior and I take a section through it, the section just shows a smooth exterior finish. What I'd like to get it to show is the correct section of the cladding profile (Dutch lap etc) instead of a smooth face.
Any ideas?
Thanks
Doug I
Walls in revit essentially have a flat face. The only was i can suggest to do this is to add a profile wall sweep to the family. But personally i would just create a detail component and place it on all the sections where this cladding is visible.
Hope this helps,
Chris.
Regards,
Chris.
Walls in section. |
Wed, Jan 19, 2005 at 5:06:54 PM
Is there a way to force walls to show section? |
Tue, Aug 4, 2015 at 7:40:31 PM
section problem |
Wed, Jun 8, 2005 at 11:06:40 PM
Cut Pattern in Plan vs Section |
Tue, Aug 25, 2009 at 8:47:59 AM
Development for Section box command in Revit |
Fri, Apr 20, 2012 at 3:50:03 PM
Members: | 2017294 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
