Forums >> Revit Building >> Technical Support >> Chamfer adge extrusion issue! Please Help!!!!!
Wed, May 22, 2013 at 11:31:31 AM | Chamfer adge extrusion issue! Please Help!!!!!
irfan77uk
Hi,
I am trying to extrude a glass panel with chamfer edges.  However i want it to be parametric, so i can change the thickness of the glass panel.  When i add a parameter for glass thickness and increase the thickness, the chamfer edge angle and size changes.  I want to retain the chamfer angle and length fixed.
Can someone please advise... I have been trying to solve this issue for hours.  Also, i want to load it into a Curtain wall panel family... Should i extrude it within the curtain wall family, or should i create it as a separate family (if so, which family?) and then load it into my curtain wall family?
 Thank you.
Wed, May 22, 2013 at 3:20:18 PM | Chamfer adge extrusion issue! Please Help!!!!!
Download and read the "Families Guide" from the AutoDESK site.  It will show you how to constrain geometry like this .... and MUCH MORE.
creating a chamfer on edges of an extrusion
Tue, Apr 21, 2009 at 5:47:05 PM
chamfer edges
Mon, Jan 18, 2010 at 11:15:46 AM
3D Fillet/Chamfer
Thu, Sep 2, 2010 at 5:31:42 PM
Foundation wall chamfer
Thu, Sep 29, 2011 at 10:58:22 AM
chamfer
Mon, Apr 7, 2008 at 4:59:25 PM
Page generation time: 1.1771
