69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Rendering and the Paint Tool
Tue, May 21, 2013 at 4:07:48 PM | Rendering and the Paint Tool
ReneeDLZ
I am trying to paint the steel channel on the left, and the model-in-place components.  Does anyone know why I can't paint them?  I was able to paint the steel channel on the left.  Thank you!!!
Tue, May 21, 2013 at 4:22:47 PM | Rendering and the Paint Tool
If you did model-in-place, then simply edit and assign the material.
Wed, May 22, 2013 at 8:19:10 AM | Rendering and the Paint Tool
ReneeDLZ
Thanks WWHub!  You're awesome...the simple stuff gets me most of the time...
I changed the column material, now I'm playing with the image material I loaded...which is more fun!  Thanks again.
Wed, May 22, 2013 at 9:19:02 AM | Rendering and the Paint Tool
Whenever possible, you should be assigning material by object rather than paint.  Paint is hard to find in the project and it doesn't show the proper material in cut views.  Try to reserve the paint tool for split face areas.
How do you tell what finish has been applied with Paint?
Sat, Jan 26, 2013 at 5:14:41 AM
Remove Paint from Walls
Wed, Feb 9, 2011 at 1:33:46 PM
Rendering Sheetrock/paint
Wed, Sep 21, 2011 at 6:10:13 PM
WALL CUT (openings) MATERIAL
Sat, Sep 28, 2013 at 10:56:04 AM
Revit Rendering
Tue, Aug 19, 2008 at 4:05:46 PM
Page generation time: 0.7641
