78 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> New Door Cuts in the Demo Plan
Tue, May 21, 2013 at 2:01:39 PM | New Door Cuts in the Demo Plan
benlink
I'm building a phased plan in Revit 2013.  All my existing doors, walls, etc. that are being demolished are showing up fine  in the demo plan-- dashed.  Though, I would like the cuts for new doors in existing walls to show up dashed.  That is, I would like the new cut to show up dashed.  So far, they do not.  I can see the infill  Help has been little help and I haven't found any tutorials that address this issue.
The specifics are:
Wall is; Phase created: Existing, Phased demoed: None.
Door is; Phase created: New Construction, Phase Demoed: None.
Existing Plan; Filter: Show All, Phase: Existing
Demo Plan; Filter: Previous + Demo, Phase: Demo
Proposed Plan; Filter: Previous + New, Phase: New Construction.
There's a pdf attached with the area in question bubbled in the Existing, Demo, and New Construction phases (Counterclockwise from top left)
Any help would be appreciated.  Thanks.
Tue, May 21, 2013 at 8:49:28 PM | New Door Cuts in the Demo Plan
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
you have to use phase filter in view properties
and you can custumize it also..
Edited on: Tue, May 21, 2013 at 8:49:58 PM
Edited on: Tue, May 21, 2013 at 9:15:03 PM
want more?
You can get more tips at Enjoy Revit
Wed, May 22, 2013 at 8:19:35 AM | New Door Cuts in the Demo Plan
dduarte
dduarte Avatar
3 Stars: 2 Votes
It looks like you are using a demo phase. Most people you talk to will tell you that demo is not a phase. If you decide to use a demo phase you have to use a few view filters to get some infill walls, doors and windows to show correctly in demo and proposed views. Add a project instance parameter to doors, windows, walls, etc. categories. Give your infill wall a value of "demo." Use a view filter in your demo plan to override the infill wall so it graphically shows as demo.Hope that helps.
Edited on: Wed, May 22, 2013 at 8:46:26 AM
David
Wed, May 22, 2013 at 8:42:55 AM | New Door Cuts in the Demo Plan
You don't demo in existing phase, demo in new.
Wed, May 22, 2013 at 1:05:33 PM | New Door Cuts in the Demo Plan
benlink
Thanks for your responses.  I have a few questions:
dinghot.  Are you referring to the "Show Previous + Demo" Phase Filter?  The infill wall for the new door to be added in the New Phase
duarte & WWHUB:  If I don't do a demo phase, to what phase should my demo plans be set?
WWHUB, the door in question is not being demolished.  It's a new door.  If I demo things in the "New" phase, I'm not sure how I would get my demo plan to show up accurately.
Finally, I suppose I have a different understanding of working with phases.  duarte, can you suggest a tutorial that describes your method.  The one's I've seen have directed me to the method I have in place.
Thanks!
Wed, May 22, 2013 at 2:06:49 PM | New Door Cuts in the Demo Plan
benlink
Ah.  I see where you're coming from.  Thanks.
Wed, May 22, 2013 at 3:10:10 PM | New Door Cuts in the Demo Plan
View phase settings and view name are two different things.  We demo in new and our demo plan shows correctly as our new plan does.  See attached.
Wed, May 22, 2013 at 3:21:45 PM | New Door Cuts in the Demo Plan
benlink
Gotcha.  I wasn't confused about the differnce between phase settings and view name...but thanks for clarifying Winking
I was confused about how I would create a demo plan with no demo phase.  I messed around a bit and figured it out:
Demo and new construction both occur in the "New Construction" phase, as you all have pointed out...and phase filters
change based on the view (Show Previous + Demo for demo and Show Previous + New for proposed).
Thanks again for your help.
new door in exisiting wall
Wed, Jan 9, 2008 at 4:40:51 PM
Phases and Section Cuts
Thu, Mar 19, 2009 at 9:49:28 AM
Demo Door Automatic new wall
Thu, Oct 4, 2007 at 10:20:30 AM
Doors IN Demo Plan
Wed, Mar 28, 2007 at 7:56:08 AM
Demo Door/New Wall
Wed, Dec 14, 2005 at 12:56:28 PM
Page generation time: 1.6166
