79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Diagramming Floor Joist Elements
Tue, May 21, 2013 at 11:45:11 AM | Diagramming Floor Joist Elements
EBtheWanderer
Good Afternoon all,
I am quite new to Revit, so I thank you all in advance for your help, and I look forward to (hopefully) being able to contribute back to the community here as my skills grow.
I am using Revit Arc '13, and seem to be having trouble indicating the direction of my floor joists. The floor type is stock System Family:Floor --> Type: Wood Joist- x12 w/T&G. In edit boundaries, I have floor direction (at least I think thats what the double lines indicate) in a manner that would clearly show joists in section view.
I am trying to figure out if either a) this particular floor (or floors in general) do(does) in fact have detailing for 16" o.c., or b) if it does not, how I might go about indicating this in a section view.
On another note, I wonder if the methods that are actually used for the above problem are applicable to diagraming wood beams & columns?
Any help is greatly appreciated.
Tue, May 21, 2013 at 12:19:15 PM | Diagramming Floor Joist Elements
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
A floor type is essentially the layers that make up a floor thickness, if you have say 11 7/8" joist your floor thickness will be 11 7/8" but it will not actually show a joist.  If you want to see an actual framing plan showing the joists you need to insert a beam family and create your beam system that way, there you can specify you O.C. spacing you require.
Tue, May 21, 2013 at 5:20:01 PM | Diagramming Floor Joist Elements
EBtheWanderer
Ah, thank you much!
floor joist layout
Thu, Dec 22, 2005 at 6:14:55 PM
Joist Seats on sloped joists
Wed, Oct 24, 2012 at 1:27:47 PM
13
How can you place a ceiling in a floor if theyre both 3D elements???
Wed, Dec 3, 2014 at 12:26:41 PM
Sloped joist line type
Thu, Nov 25, 2010 at 12:25:03 PM
Roof Joist
Thu, Jun 5, 2008 at 7:37:30 AM
Page generation time: 1.0219
