74 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Using JPEGS inside revit and then...iluminate them!
Mon, May 20, 2013 at 6:25:09 PM | Using JPEGS inside revit and then...iluminate them!
danezeq
hey everyone :-)
i just find the way to import JPEGS inside revit. i do it thrugh INSERT>>DECALS.
i saw inside an option to make the jpeg iluminate like lcd screen. i did choose this option but then i didn't see it iluminated in the final render.
was i supossed to render with artificial lights to see the renders iluminated?
Thu, May 23, 2013 at 3:35:07 PM | Using JPEGS inside revit and then...iluminate them!
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Once you set the Decal to Luminate then play with the 'brightness' setting. See image.
Fri, May 24, 2013 at 6:19:17 AM | Using JPEGS inside revit and then...iluminate them!
danezeq
thank you iwill try.
btw it doent look like LCD lighting. only more bright image.
jpegs showing up black
Fri, Mar 26, 2010 at 10:41:17 AM
Exterior shake siding & brick jpegs
Thu, Mar 6, 2008 at 2:23:30 PM
jpegs wont show up on plot
Tue, Jan 15, 2008 at 12:09:05 PM
Inside Rendering
Fri, Jun 12, 2009 at 12:42:26 PM
Rendering Walkthroughs
Wed, Nov 28, 2007 at 9:28:11 AM
Page generation time: 2.5282
