50 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How to remove SURFACE PATTERN GRID LINES on imported family component?
Sun, May 19, 2013 at 5:49:35 PM | How to remove SURFACE PATTERN GRID LINES on imported family component?
DesignBunny
1 Stars: 1 Votes
Using Revit 2013
I've used many items from the site which insert into the project looking perfect.
Then there are some items (so far every vehicle I've tried) that have their entire surface covered in a diamond grid pattern. Sometimes this pattern is grey, sometimes bright blue.
How do I remove this? I have tried altering settings in 'Override Graphics in View' but nothing changes.
I am still a new user so I don't know what else to try.
Thanks for any help!!!
Mon, May 20, 2013 at 7:24:19 AM | How to remove SURFACE PATTERN GRID LINES on imported family component?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can change the material of the family either in the actual family or in the Project.  The diamond grid that you are seeing is part of how the family was made, i'm assuming it was created in sketchup or some other program so that cannot be turned off.  It will not show up if you render the view.
Surface Pattern or Pattern Component Family for Ceiliing Linework
Sun, May 31, 2015 at 12:33:51 PM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
Demoed ceiling grid won't DASH!
Tue, Oct 23, 2012 at 9:29:08 AM
Surface pattern vs. Render Pattern
Fri, Aug 21, 2009 at 3:12:33 PM
Revit 2015, Conical Roof Surface Pattern Twist
Wed, Apr 22, 2015 at 8:57:44 AM
Page generation time: 2.1004
