Forums >> Revit Building >> Technical Support >> Poche Not Printing?
I have a plywood poche that will not print now that we are using revit 2014. Whats weird is that when I zoom into the detail and print it as fit to page and visible portion of screen it shows up correctly. When I zoom back out and print the whole 24"x36" sized sheet at zoom 100% the poche is not visible and only shows a solid white fill. I tried printing to a PDF and it has the same problem.
Anyone else having poche printing problems now using revit 2014?
The scale of you filled region is most likely to small so what you are zoomed to 100% it is not showing.
Thank you for the response.
Whats weird is that it had always printed correctly until I upgraded to Revit 2014. Now it won't print anymore : / It just shows as a solid white filled region. When I zoom in to it it shows up correctly. When I increase the scale of the drawing it prints correctly. I dont know why the upgrade from 2013 to 2014 would downgrade drawing resolutions...
I am hoping a patch will fix it in time.
anyone else have a suggestion?
Quite often, people just remember incorrectly. If you want to verify the problem, create a new file in your 2013 program and use that pattern at the same view scale and verify that it prints. Then if it really does, upgrade that file and see if it still prints. If it does, then something happened with your conversion. If it doesn't, the you need to do one more thing. Create a new file with a view of the same scale and fill pattern and print that. If that prints, then you should tell autodesk that they have a conversion problem (and you can replace the pattern in your file). If it doesn't print, then tell them that.
Thank you I will try this today and see what happens.
revit 2016 poche |
Wed, Sep 23, 2015 at 2:50:33 PM
Wall Poche and Phasing.... |
Wed, May 31, 2017 at 8:40:33 AM
Underlayer Leaves Ghosting in Poche |
Fri, Mar 13, 2015 at 7:49:29 PM
poche walls |
Wed, Jul 25, 2007 at 1:26:04 PM
Walls, Floors and Roofs to show hatch pattern AND color poche? |
Sun, Apr 29, 2012 at 12:24:19 PM
Members: | 2119216 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
