Forums >> Revit Building >> Technical Support >> 3DS MAX using Backburner scan lines problems
67 Posts No Rating |
1- I am learning how to use the backburner program and finally got two computers to render an image together. Each line, there are 22, is rendered with different lighting, making the image garbage when stitched together. see attached. Is this a common problem? any fixes or other posts about this?
2- separate question- is there a way to limit the cpu usage for a job sent to the network?
Thanks!
max and revit 2013
Edited on: Fri, May 17, 2013 at 9:44:04 AM
there is no attachment but im guessing the gamma settings on each computer are different, or perhaps you are using IES files on your local machine and the 2nd computer is unable to see them.
you can reduce the amount of cores used by max render on the individual machines by setting the affinity in task manager. theres also 3rd party apps that control it.
if you are rendering a single image why areunt you using distributed rendering? you dont need backburner
lets try the file again. it was too big...
Edited on: Fri, May 17, 2013 at 10:54:16 AM
- what is an IES file? I clicked the box for "include maps" but I am guessing its something different.
- any 3rd party apps you recommend?
- trying to learn backburner for eventual walkthrough stuff but thanks
Revit to 3ds max rendering with backburner |
Tue, Aug 4, 2009 at 5:01:20 PM
backburner on all office computer |
Thu, Oct 6, 2011 at 10:28:04 AM
problems inporting from revit 2010 to 3ds max 2010 |
Sun, Mar 13, 2011 at 6:18:00 AM
Revit bring into 3ds Max [ 1 2 ] |
Sat, Dec 25, 2010 at 6:24:34 PM
17
problems with Revit 2013 in 3ds Max! |
Fri, Dec 14, 2012 at 4:25:45 PM
13
Members: | 2098007 | Objects: | 23164 | Forum Posts: | 152290 | Job Listings: | 3 |
