Forums >> General Discussion >> Revit Project Management >> 'Surface Pattern' and corresponding 'Region Fill' appear differently.
Fri, May 17, 2013 at 9:11:54 AM | 'Surface Pattern' and corresponding 'Region Fill' appear differently.
Chunkymonkey
5 Stars: 3 Votes
Greetings,
I am putting together a floor finishes plan.
I have given each of the different floor finishes in the model a 'Surface Pattern' ie 'cross hatch', in the material properties dialogue box.
I have then created a floor finishes legend using 'Region Fill/s' that correspond to these. Now when I put both the floor finishes plan view and the legend on a sheet, the 'Surface Patterns' on the plan appear slightly greyed and the corresponding 'Region Fills' in the legend appear more black and crisp on the print out.
All colours for the 'Surface Patterns' and 'Region Fills' have been set to black.
How can I get the patterns on the plan to appear black.
Many thanks,
CM.
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Fill Region not visable
Thu, Oct 5, 2006 at 4:12:10 PM
Fill Pattern requirements
Mon, Apr 10, 2006 at 10:41:09 AM
I can't select Fill Regions
Sat, Oct 21, 2006 at 12:54:47 PM
Tough one - Phased site topography and visibility in section
Thu, Jun 9, 2011 at 11:58:34 PM
Page generation time: 5.1975
