75 Users Online (72 Members):
Forums >> Revit Structure >> Technical Support >> Revit Structure 2013 windows 7 & windows XP Compatibility
3 Posts No Rating |
Can anyone help me out it
This situation:
A central model file was created in a Revit structure 2013 x86 (windows xp). other Users with Revit structure 2013 x64 (windows 7) need to access & modify the central file but it only opens but could not save or take ownership of any workset.
Is there a fix or an updated for this?
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
You should rarely take ownership of an entire workset. Are you getting any errors? Are you sure its a central file? If its a central file and someone owns all of the worksets you need them to sync and release the worksets.
You should not be editing the central anyway, always open with create a local checked.
And as tefoe says... Is it really a central file?
Windows 10 |
Fri, Aug 7, 2015 at 10:11:53 AM
Revit 2010 compatibility with Windows 8 |
Thu, Dec 6, 2012 at 6:24:09 AM
Release Compatibility Structure - Architecture - Etc? |
Tue, May 17, 2011 at 1:57:25 PM
painting split walls with windows |
Thu, Nov 15, 2012 at 3:17:04 PM
Revit Architecture 2012 Compatibilty with Windows 10 |
Thu, Feb 14, 2019 at 4:59:13 AM
Members: | 2016941 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
