153 Users Online (152 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> wall wraps
Tue, May 14, 2013 at 10:03:03 AM | wall wraps
Oke guys,Could you tell me why 1 wall has the options to turn on wall wraps and the other wall (same but different name(different type)) has NOT the ability to turn on wall wraps?I'm hardly confused...I've uploaded a purged .rvt file with the 2 walls. Just try to wrap the one which isn't wrapped yet. I couldn't do it... Could someone else explain this or solve this problem?Thank you,Sef
Tue, May 14, 2013 at 11:12:06 AM | wall wraps
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
A core layer cannot be wrapped.  You need to move your Finish and thermal layers UP and then you will be able to wrap them
Tue, May 14, 2013 at 12:04:25 PM | wall wraps
Thank you very much!
That solved the problem Smile
Wall Wraps
Fri, Oct 17, 2008 at 1:17:25 PM
13
Wall wraps at inserts
Tue, Jun 28, 2016 at 3:50:38 PM
Door deletes when I edit wall type.
Mon, May 1, 2006 at 2:27:03 PM
wall wraps
Tue, Jan 31, 2006 at 4:47:15 AM
Wall wraps
Tue, Sep 25, 2007 at 11:29:19 AM
Page generation time: 4.5531
