34 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How to resize spot elevations
Mon, May 13, 2013 at 3:32:50 PM | How to resize spot elevations
Archiguy
Hello all,
Trying to  reduce the size of the spot elevation icon, as it's slightly larger than the level symbols.
I went to families , and double clicked on "spot elevtions- target filled" which is the type i want to edit. I get the "type properties" box.
But I cannot make any changes here. Below the "type parameters" is greyed iut info that is not editable.
I tried the same steps after duplciating the type, but to no avail.
Appreciate any input!
thanks
Mon, May 13, 2013 at 3:35:40 PM | How to resize spot elevations
You have to edit the family - not the type.  You will find it in your browser under annotations.
Setting a manual height for Spot Elevations in plan
Wed, May 27, 2015 at 8:03:12 AM
Spot elevations
Fri, Jul 29, 2016 at 8:01:29 AM
Revit Spot Elevations, Rooms and Color Schemes Problem
Mon, Jun 24, 2013 at 12:46:36 PM
Revit refusing to use Spot Elevations
Mon, Oct 14, 2013 at 3:47:55 PM
13
rotating spot elevations on plan
Fri, Mar 6, 2015 at 12:14:15 PM
Page generation time: 1.1789
