35 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Creating Revit Topo from AutoCAD file
Mon, May 13, 2013 at 9:50:56 AM | Creating Revit Topo from AutoCAD file
harleyrose
Afternoon all,
I have an autoCAD file with topo levels (modelled with Z value)
I am trying to create a surface in Revit but it doesnt allow me to select the imported DWG and there are too many spot levels to do point by point.
Can someone help please.
Thanks
Mon, May 13, 2013 at 9:56:29 AM | Creating Revit Topo from AutoCAD file
This is really easy.  Just follow the directions in your HELP:
Creating a Toposurface
Mon, May 13, 2013 at 11:05:02 AM | Creating Revit Topo from AutoCAD file
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
The help files in Revit are really good. There is some excellent videos on youtube as well. Normally I import the dwg file and then under the site tab, I create a topo from that dwg file. You'll probably need to massage some of the topographic levels to make it perfect but all in all its a brilliant quick result.
Tue, Mar 6, 2018 at 10:03:58 AM | Creating Revit Topo from AutoCAD file
IcartBlack
Similar issue, just a basic question.
Civil didnt provide topo lines on thier site evaluation, only spot elevations.
Any comments/recomendations how to handle contouring with spot elevations?
Tue, Mar 6, 2018 at 10:23:24 AM | Creating Revit Topo from AutoCAD file
All explained in your HELP.   To use a points file
Tue, Mar 6, 2018 at 6:07:17 PM | Creating Revit Topo from AutoCAD file
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Also make sure the cad file isn't 'pinned' and the selection settings on the lower left isn't set to 'Not Select Pinned Elements. You can't use what you cannot select. . .
Wed, Mar 7, 2018 at 8:30:50 AM | Creating Revit Topo from AutoCAD file
IcartBlack
countored site complete!
thanks for navigating the help, thats a lot to take in when you are trying to be quick.
creating a scv file in autocad to use in revit
Wed, Oct 14, 2009 at 10:24:12 AM
Topo Surface from autocad into revit
Tue, Oct 13, 2009 at 10:37:25 PM
CREATING A TOPO FROM A CIVIL CAD FILE
Fri, Sep 29, 2017 at 3:22:33 PM
Has anyone find an accurate way of creating topo Surface from import
Tue, May 29, 2012 at 7:42:09 AM
Importing / Modifying Topo from AutoCAD
Thu, Feb 16, 2012 at 11:14:10 AM
Page generation time: 3.7334
