87 Users Online (85 Members):
Forums >> General Discussion >> Revit ROI >> Empty layers in DWG-file.
61 Posts No Rating |
When i export dwg-files from Revit i get multiple layers that are empty. Why does Revit export empty layers?
..A follow-up question. In the attached image you can se a layer called: A-DETL, where in Revit do i change the color of this item/layer?
Thank you.
Changing color for imported dwg files are similar as mentioned in the link here.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=29146
Its not imported files. Well some of them are but they are the color they should be.
The "A-DETL"-Layer contains a Detail item made in Revit. Where do i change the green color of this layer in Revit?
Keep .dwg Layers when exporting .rvt to .dwgPlease |
Wed, Feb 24, 2016 at 9:27:59 AM
REVIT 2013 - Export DWG Layers Text File Location |
Fri, Aug 3, 2018 at 4:44:52 PM
DWG/DXF layers. |
Wed, May 31, 2017 at 7:05:57 AM
DWG Export Setup for particular layers? |
Wed, Jul 24, 2013 at 3:22:41 PM
exporting to dwg - load layers from standards |
Thu, Jul 16, 2015 at 5:24:59 PM
Members: | 2022253 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
