87 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> stepped underside of straight run monolithic stair
Sun, May 12, 2013 at 9:23:48 PM | stepped underside of straight run monolithic stair
dstrautman
Hi,
Im trying to get the underside of my monolithic stair (component based 2013) to be stepped like the top for a zig zag section.  Can't figure it out.  Any ideas?
Thx,
David
Mon, May 13, 2013 at 7:58:36 AM | stepped underside of straight run monolithic stair
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Click the stair command then under properties click edit type, then in the Type Properties under Construction>Run Type click the ... and it will bring up the type properties for the stair and under Construction>Underside Surface change it to Stepped.
Mon, May 13, 2013 at 3:04:56 PM | stepped underside of straight run monolithic stair
dstrautman
worked like a charm!  Thank you!!
Thu, Dec 12, 2013 at 3:05:44 AM | stepped underside of straight run monolithic stair
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
May I know how to achieve the same in Revit 2011.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Tue, Dec 17, 2013 at 6:04:39 AM | stepped underside of straight run monolithic stair
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
So can I assume that it can not be done in R2011?
Pavan Reddy
Revit Manager
Tue, Dec 17, 2013 at 7:39:26 AM | stepped underside of straight run monolithic stair
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't have 2011 and I don't remember the process so I'm not much help sorry.  Hopefully someone else can step in.
Problems witha amonolithic stair
Wed, May 23, 2007 at 2:15:42 PM
monolithic stair join at floor slab
Wed, Sep 24, 2014 at 11:30:36 AM
REVIT 2015 Stair - Straight Run to Curve Run
Thu, Dec 4, 2014 at 11:07:00 PM
Ye Olde Curved Monolithic Stair
Wed, May 29, 2013 at 8:31:15 AM
Issues with underside of stair
Tue, Mar 15, 2011 at 3:27:08 PM
Page generation time: 0.4863
