89 Users Online (88 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> framing plans
Fri, Feb 3, 2006 at 5:36:48 PM | framing plans
basia
does anyone have any good suggestions about how to create residential framing plans?
Sat, Feb 4, 2006 at 4:27:42 AM | RE: framing plans
latemore
latemore Avatar
3 Stars: 2 Votes
we are newbies, using revit for only 12 months. we do lots of residential here in brisbane. framing plans that we do - we do not insert structural members, we just use floors and roofs. we create copies of views, then control it with visibility/view range, until it looks right. then we simply use drafting lines to represent the joists/bearers/rafters. simple and it works for us. others may have other ideas.
Sat, Feb 4, 2006 at 7:34:08 PM | RE: framing plans
josta
1 Stars: 1 Votes
Two-month noob here. LOL Use the "Beam System" in the "Sructural" tab, or for a truss system, use it in "Beams", then array it. For roof rafters, I use the "Beam System" after setting the work plane in an elevation. It wasn't easy since I'm mostly self-taught, but you may want to consider Autodesk's Subscription Support program; they've been very helpful in my learning process. JOHN Post edited on 2006-02-04 19:35:08
John Acosta ARA, Architect
Mountain Architecture, Big Bear Lake CA
Sun, Feb 5, 2006 at 10:49:09 AM | RE: framing plans
Dgodfrey
4 Stars: 4 Votes
We've been using a third party engineering program (TJXpert) which will generate every piece and part of the framing system which can be imported then exploded into the Revit drawing. it has worked flawlessly and allows manipulation of individual parts i.e. joists can be shifted to avoid a toilet drain. generates take-offs, BOM, etc. There are others out there that are easier to get your hands on which may also work.
Wed, Jan 10, 2007 at 4:28:43 PM | framing plans
welcomehomestudio
2.5 Stars: 3 Votes
I am completing a set of residential CD's in Revit for the first time. As I add the structural, the sheets are getting big for .PDF format. (200MB range for each sheet) Any structural framing plans need to take advantage of Revit's ability to store data in a parametric way. Drafting lines onto views make the final sheets(some have 7 to 10 views) into large files in the .PDF format. Large files are slow to send over the internet..my set of (9) 24 x 36 sheets takes over 10 minutes.
Since these posts are rather old, I wonder if anyone has developed a Revit way to do the framing plans? Some money could change hands for that kind of info!
How do I make framing plans?
Tue, Jul 27, 2004 at 3:28:28 PM
Structural Framing Plans/Callout Beam Sizes
Wed, Feb 22, 2006 at 5:49:11 PM
Framing Plans
Wed, Oct 1, 2008 at 5:25:09 AM
Creating 2D Framing Plans
Tue, Oct 21, 2008 at 8:39:00 AM
Floor plan is missing in view
Fri, Nov 4, 2016 at 10:03:47 AM
Page generation time: 0.5582
