52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit2013 - Change Family To Cuttable?
Tue, May 7, 2013 at 11:47:30 AM | Revit2013 - Change Family To Cuttable?
TerribleTim
Hey gang, I have a non-cuttable family that I want to make cuttabel. It is a Specialty Equipment family, and it needs to stay a Specialty Equipment family. I already thought about changing it to a different family type, but that will introduce other problems into the mix so it isn't really an option.
Is there any way to make a non-cuttable family cuttable?
Tue, May 7, 2013 at 12:33:45 PM | Revit2013 - Change Family To Cuttable?
You might try creating a family in a cuttable category and nesting that in your specialty category.
Tue, May 7, 2013 at 12:43:35 PM | Revit2013 - Change Family To Cuttable?
TerribleTim
That's an interesting idea, I may give that a shot. I have a feeling this may just be one of those "No, you can't do that" moments.
Tue, May 7, 2013 at 12:58:14 PM | Revit2013 - Change Family To Cuttable?
TerribleTim
Ok, did a quick test. Made a generic family, nested my Specialty Equipment family in it, then loaded it into the model. Oddly enough, it worked! It does cut correctly when viewed in Section ro Interior Elevation views.
Huge thanks for the idea! I'm sure I'll have some work ahead of me to clean it up and get everything looking correct and tagged correctly. But it's a starting point.
Ok, one more update. I can't get it to schedule this way. So this may not work either.
Edited on: Tue, May 7, 2013 at 1:07:49 PM
Problems with materials, lines and patterns of imported objects!
Mon, May 17, 2010 at 4:10:01 PM
In Place furniture not cutting
Wed, Oct 21, 2009 at 12:16:46 PM
revit 2014 grouped unit- interior elevations
Fri, Apr 10, 2015 at 8:02:49 AM
Elavations in site model,sketchup model items behind appearing in view
Thu, Mar 8, 2012 at 7:32:11 AM
Cutting Sections through imported Autocad 3d objects
Fri, Dec 18, 2009 at 12:39:53 PM
Page generation time: 1.0733
