78 Users Online (76 Members):
Forums >> Revit Building >> Technical Support >> overriding materials for linked model revit
1 Posts No Rating |
how can I get a material from a linked model overriding in the project model? the linked model is from a third party which I do not have the rights.
The linked model will use the hosted model materials of the same name.
![5 Stars: 3 Votes](/images/stars_5.gif) |
'transfer project standards' allows you to import materials, filled patterns, etc. from a linked model.
![crwinchester Avatar](user_avatar/187252.jpg)
![4 Stars: 5 Votes](/images/stars_4.gif) |
I'm having the issue where the cut pattern does not display no matter if the materials are shared, the graphics are overridden, or view is set to medium or fine. How else can you make the pattern from the linked model show? I'm almost out of options. Thanks.
Solved.
A: transfer project standards as was mentioned.
B: Columns in Structural model were set to "pre-cut when loaded." Uncheck this option and override materials.
C: Reload model and viola!
Overriding grids of a linked model in view |
Wed, Oct 30, 2019 at 10:46:45 AM
Linked file materials 2016 |
Thu, Mar 3, 2016 at 3:43:15 PM
Linked Revit Model Sheets |
Fri, Apr 5, 2013 at 12:04:28 PM
Not able to place room copied from linked model |
Wed, Mar 18, 2015 at 8:10:37 AM
Switches in a mirrored linked revit model |
Fri, May 22, 2020 at 7:44:20 AM
Members: | 2022294 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
