48 Users Online (47 Members):
Forums >> General Discussion >> Revit Project Management >> Rebar Reinforcment Material takeoff
1 Posts No Rating |
I want to know about your experience using Material Takeoff.I need to make a schedule of rebar of all concrete columns and beams of a 12 level building.
I need to show the total weight of reinforcement
Do you know the best method to do that?.
Unless you actually model all of the rebar in Revit (which I don't suggest) you will most likely have to do this by hand. You might also be able to add a shared parameter to include in your beams and columns for rebar sizing, lengths, etc. and then use a multi-catagory tag to schedule the information. Not sure how this would help with total weight however, you would still most likely need to do that by hand.
Material Takeoff |
Mon, Apr 27, 2015 at 7:32:15 AM
Ceiling Material Takeoff |
Thu, Feb 15, 2007 at 3:19:57 PM
Material Takeoff issue |
Mon, Oct 25, 2010 at 3:48:35 PM
Material Takeoff for insulation?? |
Mon, Oct 28, 2013 at 9:57:10 AM
Sheathing Material Takeoff |
Mon, Apr 25, 2011 at 7:01:06 AM
Members: | 2017222 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
