Forums >> Revit Structure >> Technical Support >> MiTek Sapphire to REVIT
Fri, May 3, 2013 at 1:23:59 PM | MiTek Sapphire to REVIT
brianshott
Having trusses designed by a company which uses MiTek Sapphire which says is powered by Autodesk on the viewer.
I need these trusses in my 3D model because of the intricate design and layouts of them.
Has anyone found a way to bring in 3D files from Sapphire (.mmdl) to either CAD or Revit. As long as I can get it into AutoCAD I’m ok.
Fri, Oct 4, 2013 at 1:06:38 PM | MiTek Sapphire to REVIT
JDroski
I would also like to know if there's a way to do this.  I'm working with a subcontractor who has used this and would like to use it to help with the clash detection process in navisworks.  I can't seem to find anyway to bring a .mmdl type file into a  3d model, be it cad, revit, or directly into Navisworks.  Hope there is some way to do it.
Mon, Apr 20, 2015 at 11:10:16 AM | MiTek Sapphire to REVIT
SBurdettStarPrebuilt
No,
Due to proprietary concerns, this is unfortunately just a one-way conversion.
You CAN, however, insert an exported 3D AutoCAD drawing into the model, but you can't do a proper clash detection with it... Remember, CAD is "dumb", and Revit will not recognize a drawing as a solid entity. To get the 3D .dwg to become recognizable, you have to then convert it to a solid through Navisworks (Simulate, not Manage), which is a costly enterprise if that is all you are doing with that platform.
This is the only way I know how to do this. If anyone else out there knows more about it, please let us know!
-S2
New to Revit
Fri, Sep 21, 2018 at 10:11:30 AM
Easier way to do curbing
Tue, Dec 20, 2011 at 3:33:35 PM
Revit for Construction Documents [ 1 2 ]
Tue, Jan 24, 2012 at 10:57:38 AM
20
4D simulation in Revit? [ 1 2 ]
Mon, Jan 17, 2011 at 11:27:39 AM
18
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ]
Thu, Jan 6, 2011 at 3:25:02 PM
18
Page generation time: 2.7020
