136 Users Online (133 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> bottom chord extension on joist
Thu, May 2, 2013 at 7:15:40 AM | bottom chord extension on joist
wbrowland
I am new to Revit. How do I add a bottom chord extension to joists? I know that I can change the seat, but not sure how to go about doing it for the bottom chord.
Tue, May 7, 2013 at 1:33:43 PM | bottom chord extension on joist
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I thought you could drag the bottom chord but I just tried and I don't see how either.  However if you edit the family (be careful if your new) there is a dimension and reference lines that lock the location of the bottom chord extension that you can add a parameter to for each side of the truss such as Bottom Chord Start Offset and Bottom Chord End Offset.
Joist Top Chord Extension
Wed, Jul 7, 2010 at 11:45:50 AM
DLH joist bottom chord bearing
Thu, Dec 9, 2010 at 8:40:10 PM
Single Pitch Top Chord Joist family?
Fri, Nov 30, 2012 at 7:49:30 AM
DLH Joist Bott. chord brg. sloped top chord
Mon, Dec 13, 2010 at 1:07:53 PM
Joist Top Chord Extensions
Mon, Apr 26, 2010 at 10:07:37 AM
11
Page generation time: 0.7406
