71 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> brick sills under windows
Fri, Feb 3, 2006 at 12:51:50 AM | brick sills under windows
leeroy
I am having trouble inserting brick sills under windows automatically. can anyone suggest the fastest way of doing this?
Fri, Feb 3, 2006 at 6:11:45 PM | RE: brick sills under windows
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Build it into the family. Then reload it and they'll all update.
Sat, Feb 4, 2006 at 5:20:41 AM | RE: brick sills under windows
jyothi
hi, U can also use wall sweep to create brick sill. cretae a profile of required size and load to project and use wall sweep. Regards
Sat, Feb 4, 2006 at 9:28:06 AM | RE: brick sills under windows
latemore
latemore Avatar
3 Stars: 2 Votes
jyothi can i ask a dumb question - we have done this on clad walls, and have to put the sweep 1mm below the window opening so the window itself does not 'break' the sweep. is good enough. is there a better way to do this? also with brick sills on brick veneer type walls, how are you showing the angled sill coming from the inner skin, as a sweep, or am i missing something? mr spot's answer is the only way i have seen it done, and if there is another, love to know it!
brick sills under windows in a family
Tue, Feb 7, 2006 at 5:22:23 AM
Wall Recesses
Fri, Jul 9, 2010 at 9:49:01 AM
APPLYING SILLS TO WINDOWS USING A SWEEP
Thu, Jun 9, 2005 at 3:58:34 PM
Window Sills in Revit Arch. 2008
Thu, Dec 27, 2007 at 9:12:45 AM
Windows Centered to Core
Thu, Dec 7, 2006 at 9:53:27 PM
Page generation time: 0.9676
