108 Users Online (107 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> CONCRETE UP-STAND SWEEP WITH RISERS AND TREADS
Mon, Apr 29, 2013 at 12:59:23 AM | CONCRETE UP-STAND SWEEP WITH RISERS AND TREADS
adgreen
Greeting,
want to ask if Revit can make conc. upstand for stair, with BASE  sweep on treads and risers..?
Mon, Apr 29, 2013 at 3:40:42 AM | CONCRETE UP-STAND SWEEP WITH RISERS AND TREADS
4 Stars: 203 Votes
That dwg file is nothing to me, if you are asking if revit can create a monolithic stair with treads and risers the answer is YES.
Mon, Apr 29, 2013 at 3:50:44 AM | CONCRETE UP-STAND SWEEP WITH RISERS AND TREADS
adgreen
I'm asking if revit can make conc. up stand family for the stair That run ( in the base) parallel with treads and risers
Mon, Apr 29, 2013 at 3:56:43 AM | CONCRETE UP-STAND SWEEP WITH RISERS AND TREADS
4 Stars: 203 Votes
You want the "base" of your Monolithic stair "Stepped"??? you have an option for that in the stair's properties.
Mon, Apr 29, 2013 at 4:05:11 AM | CONCRETE UP-STAND SWEEP WITH RISERS AND TREADS
adgreen
Ok , will check it, thanks for you
Connecting walls to stringers / hiding treads and risers
Thu, Nov 18, 2004 at 1:20:39 PM
RC Staircase and Levelling Concrete Issue
Fri, Aug 12, 2016 at 7:21:06 AM
stair help with tread AND railing
Wed, Jul 3, 2013 at 12:23:09 PM
Radial tread / risers in Revit 2013
Thu, Jun 20, 2013 at 8:05:41 AM
Stair Stringer Cutting Stair Treads and Risers See Image
Thu, Jun 5, 2014 at 7:59:39 AM
Page generation time: 0.7180
