Forums >> Revit Building >> Technical Support >> Help! Print settings changed and don't know what to fix
4 Posts No Rating |
So I must have changed a setting somewher and only my 2nd floor is printing like crap. With and without shadows, print to PDF or export to TIF
All my other plans, elevations work fine, I have tried to fix the settings to match on the sheet and the view with no avail....Has this happened to anyone?
Using Revit 2013
Using Revit 2013
make a quick template from a like view that is showing correctly and apply it to the view in question.
4 Posts No Rating |
I save a new print template and it still is printing "unfocused" here is the new PDF. Could it be anything with the components on this floor?
here is the DB file location.
https://www.dropbox.com/s/0ui7toospklyhnv/Hotel%20Tvaalittle.rvt
I was referring to a view template, I don't know what a print template is. Also are printing raster or vector?
Edited on: Sun, Apr 28, 2013 at 11:11:36 AM
4 Posts No Rating |
It worked!! I have no clue what setting I changed, but I have a ledgable floor plan, thanks to you.
Also I was printing Raster due to the shadows needed.
Thanks!
elevation arrowhead don't show up at print |
Tue, Nov 14, 2006 at 1:26:58 PM
Masses Don't Print?!? |
Thu, Feb 24, 2011 at 2:47:52 PM
Materials don't print in some areas (Revit Arch 2008) |
Fri, Feb 8, 2008 at 4:11:32 PM
What I see in revit I do not print |
Thu, Mar 3, 2016 at 10:35:36 AM
Detail components won't print |
Thu, Mar 28, 2013 at 7:15:49 AM
Members: | 2100741 | Objects: | 23171 | Forum Posts: | 152296 | Job Listings: | 3 |
