47 Users Online (46 Members):
Forums >> Revit Structure >> Technical Support >> Cutting out section of floor at edge
38 Posts No Rating |
Hi,
I need help with cutting out the section of the floor slab at the edge. In the picture, you can see how the slab is going through the beam. Well, we want it to jag up just at the edges and sit on top of the beam. What is the best way to do this? I was just going to mask it all, but that is time consuming. Thoughts?
I would just use edit cut profile in that detail.
Thanks for the reply.
When I go to the cut command, it asks for a family to cut with? It won't pick the beam, and I tried a reference line as well.
Ok. I got it. I was using just the cut comman, not the cut profile. Thanks!
The edit cut profile is a great toool - learn to use it and you will use more of your model. The ONLY problem is the cut-profile lineweight is not definable. Hope that is fixed in 14.
Also remember cut profile is view-specific. It does not actually alter the model element.
Thickened Slab Not Cutting Floor Line Out |
Wed, Dec 28, 2011 at 7:54:13 AM
window not cutting joined roof |
Mon, Mar 6, 2017 at 4:23:50 PM
Joining a Floor to a Roof????? Help! |
Sat, Mar 5, 2011 at 12:42:27 PM
floor slab edge |
Fri, Aug 22, 2008 at 3:31:34 AM
Composite floor edge |
Mon, Oct 1, 2007 at 8:38:41 AM
Members: | 2017222 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
