111 Users Online (109 Members):
Forums >> Revit Building >> Technical Support >> artificial lights not rendering
2 Posts No Rating |
The track lights are not lighting up. Family seems to be correct yet nothing is working. I have played around with the settings and tried to increase it. The host of the track lights is the floor but is offset to the height I need.
Also, the recessed lights which are hosted onto the ceiling are not bright enough...
Please help !
![Beaucoupnice Avatar](user_avatar/46219.jpg)
![3.5 Stars: 6 Votes](/images/stars_3.5.gif) |
In render window did you use the artificial lights option? Or just use sun? If only the latter, the artificial lights won't come on.
Open that light family, create a Glass element in front of that light and change the material / luminance, this will give you the effect you want
2 Posts No Rating |
Thanks all ! The problem was that in the family the front material was a solid !!
thanks typhoon
Revit 2009 - interior rendering with exterior sun and artificial lights |
Fri, Oct 10, 2008 at 10:25:18 AM
lighting scheme and artificial lights |
Mon, May 19, 2008 at 9:21:47 PM
rendering: can't get itnerior lights turned off |
Mon, Feb 27, 2012 at 6:14:44 AM
Revit always renders all of the lights |
Fri, Aug 8, 2014 at 9:24:36 AM
Night Rendering with artificial lighting? |
Sat, Jul 18, 2009 at 8:17:29 PM
Members: | 2017084 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
