36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Loading families
Thu, Apr 25, 2013 at 7:52:41 AM | Loading families
adgreen
When im loading my families, always recieving a warrning :YOU MUST CHOOSE FAMILY FILES OF THE CATEGORY COMPONENT...
anyone know the steps should done,  to go forward wiih our families...?
Thu, Apr 25, 2013 at 8:03:55 AM | Loading families
3.5 Stars: 395 Votes
This problem occurs when you are in a view and process that is specific. For instance loading a plumbing fixture after starting the column process or being in a drafting view and loading a model element.  Generally if you are just loading families into a project, try actually being in a floor plan with no active commands.  You have to be in the plan - not just have it open on your screen. - click in the plan after opening it.
Thu, Apr 25, 2013 at 8:48:35 AM | Loading families
adgreen
Did it... But still appearing the warning..
Thu, Apr 25, 2013 at 11:23:05 AM | Loading families
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You are trying to insert a family that is not compatable with what command you are trying to insert it with. For example if I click on the Window command and go to insert family and try to insert a door I will get the warning you are recieving.
 Go to Insert>Load Family (without picking any other command) and find the family that you want to load and load it into the project.
Loading Families
Mon, Nov 23, 2015 at 7:25:45 AM
Loading Families
Tue, Apr 21, 2009 at 4:41:24 PM
Issues with loading downloaded families
Thu, Jan 9, 2014 at 12:11:36 PM
Revit Architecture 2015 - Families not loading
Mon, May 25, 2015 at 10:44:08 AM
Fri, Feb 1, 2013 at 11:15:08 AM
Page generation time: 0.4798
