43 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Roof - Extrusion Along path - Conceptual Mass - 3D curve
Wed, Apr 24, 2013 at 9:18:19 AM | Roof - Extrusion Along path - Conceptual Mass - 3D curve
kubbah
Hello,I would like to creat this 3D roof geometry, but I don`t know which is the best way of doing it?
The roof edge is curved in plan and in elevation.
I would like to "extrude along path" the edge profile.
what is the best way?Thanks
Wed, Apr 24, 2013 at 9:28:03 AM | Roof - Extrusion Along path - Conceptual Mass - 3D curve
I would just do the main roof area then add an in-place family as a sweep along the edge and join the two.
Wed, Apr 24, 2013 at 9:35:00 AM | Roof - Extrusion Along path - Conceptual Mass - 3D curve
kubbah
Could you be more detailed?
There is no "sweep along the edge" command in the in place mass editor...
thans
Wed, Apr 24, 2013 at 9:45:58 AM | Roof - Extrusion Along path - Conceptual Mass - 3D curve
Whenever possible, use Revit elements instead of masses.  If the main area of this roof can just be done as an extrusion from a side profile, then do that and an in-place sweep (roof category) along the edge.
Revit is a real world program - not just conceptual.  If you are really doing a building, at some point in time you need to define the geometry in a way that it can be built.  A mass is easy to play with in 3D but if you have to use standard methods and materials to really build something, then converting a mass to Revit defined elements can be problamatic.  Yes ... you can do wall/roof/floor by face but itnone of these elements have defined layers that show in revit views - just surfaces.
So - if it must be a mass.... Create the main area of the roof and add a sweep along the edge.  (Model in place tab - mass category)
Edited on: Wed, Apr 24, 2013 at 9:47:11 AM
Wed, Apr 24, 2013 at 10:04:16 AM | Roof - Extrusion Along path - Conceptual Mass - 3D curve
kubbah
I tried to apply a fascia or a gutter on the roof but it is not generated becouse of an error, probably because  it is curved....
Conceptual mass:
I am in the "Edit in-place" modality
but i cannot find any "sweep along the edge" ...
Wed, Apr 24, 2013 at 11:07:37 AM | Roof - Extrusion Along path - Conceptual Mass - 3D curve
It is a "Sweep" ...."along the edge"..not one command... Do a sweep and pick the 3dEdge as the path.
Attached is an arched roof with "gutter" along the arched edge.   It is a gutter profile but the usage was changed from gutter to facia.  The facia profile can be used along any roof edge but a gutter can only be used along a straight edge.
Wed, Apr 24, 2013 at 11:19:48 AM | Roof - Extrusion Along path - Conceptual Mass - 3D curve
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
@kubbah : There is no "sweep" tool in that template. But "Create form".
Edited on: Wed, Apr 24, 2013 at 11:41:22 AM
Planta1 Revit Online Consulting | info@planta1.com
Wed, Apr 24, 2013 at 11:20:54 AM | Roof - Extrusion Along path - Conceptual Mass - 3D curve
kubbah
"It is a "Sweep" ...."along the edge"..not one command... Do a sweep and pick the 3dEdge as the path."
In which environment? "conceptual mass family environmetn? "in place mass" environment? or other? Which commands shell I use?
"in place mass" project environment there is only "create mass" tool, if I pick a path and then the profile it creates an error (self intersecting bla bla).
Regarding the FASCIA TOOL
It it is an arched roof it workes for me as well,
but if there is an arch on elevation and plan as well, it doesnt work...
Thanks
Wed, Apr 24, 2013 at 12:02:41 PM | Roof - Extrusion Along path - Conceptual Mass - 3D curve
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
In a generic adaptive template, use reference splines for the curves, and reference lines for the straight edges. In elevation, use named reference planes to change the host of the points. Then select the two curves, and do "Create form".
Thu, Apr 25, 2013 at 1:57:56 AM | Roof - Extrusion Along path - Conceptual Mass - 3D curve
kubbah
Hmm , let me try,
and how can I import a geometry of the roof I have done in the project envionment with the in-place mass?
Thanks
Thu, Apr 25, 2013 at 1:19:11 PM | Roof - Extrusion Along path - Conceptual Mass - 3D curve
kubbah
The problem with that is that I need to then draw 3 edges.
And how can I do it isint the extrusion profile along the edge?
In this way I coild control the profile...
thank you
Thu, Apr 25, 2013 at 1:28:03 PM | Roof - Extrusion Along path - Conceptual Mass - 3D curve
Is the edge profile the same all around?
Thu, Apr 25, 2013 at 1:47:26 PM | Roof - Extrusion Along path - Conceptual Mass - 3D curve
#13
kubbah
3 sides yes,
1 side is different. I would need to then make a connection bit probably..
conceptual mass -newbie to that
Mon, Feb 21, 2011 at 9:21:36 AM
Joining Roof By Extrusion
Mon, Jan 31, 2011 at 8:15:14 AM
Update Structural Framing with Updated Conceptual Mass?
Thu, Mar 12, 2015 at 6:54:55 PM
Revit 2012 Roof by extrusion
Sat, Nov 19, 2011 at 4:49:20 AM
Modifying Mass - Moving edge creats curve instead of angles/facets.
Sat, Sep 7, 2013 at 1:36:37 AM
Page generation time: 1.4251
