Forums >> Revit Systems >> Technical Support >> Pipes display as solid in section
3 Posts No Rating |
I have a section view that shows hot and cold water and heating pipes etc and natural gas and drainage. All of them display as solid in the section except for natural gas which shows as a line and riser symbol which is fine. I've tried to figure out why the pipes show like this but have had no luck. This section is in fine detail, when in medium or coarse the pipes show as big circles but all the same size even though they are different sizes. Any ideas?
REVIT MEP 2013 ? Please always provide a screen capture. Use Windows Snipping Tool.
3 Posts No Rating |
Hi dgcad, thanks for replying, yes its 2013, here's a picture of what I mean
I don't work with Pipes a whole lot but it may be because your scale is set to 1:100, have you tried scaling the drawing up a bit more, maybe to 1/16 or 1/8 and see if that helps
3 Posts No Rating |
Nah doesnt work, I'm stumped, surely there must be a fair amount of people with this problem? The gas and LTHW pipes have the same properties by the looks of it but show up different....very wierd
Edited on: Thu, Apr 25, 2013 at 9:28:33 AM
Display pipes - solid on current level, dashed if above |
Wed, Sep 6, 2017 at 2:46:27 AM
REVIT MEP 2012 Demo Phasing Disconnecting Pipes |
Wed, Jul 18, 2012 at 12:20:03 PM
How to divide pipes into different categories |
Thu, Oct 18, 2007 at 5:52:35 PM
Duo pipes - Twin pipes for central heating |
Wed, Jan 16, 2019 at 3:48:54 PM
Adding shading to a solid? |
Tue, Jul 29, 2008 at 10:51:24 AM
Members: | 2100247 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
