62 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Wall not showing in section
2 Posts No Rating |
I have a wall that is not showing up in my section. It shows up in all the other views, and it will show up in the section as long as I'm not cutting through a window. I have a sweep in the wall that is visible, but the rest of the wall is not. I have tried changing the clip setting, and have checked all the visibility options. Is this just a Revit glitch?
Not enough information. Post images and explain this: "... it will show up in the section as long as I'm not cutting through a window..."
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
Are you using Phases or Design Options or Worksets ?
2 Posts No Rating |
I figured out how to fix it, but I still don't know the reason. I deleted the window and placed a new one in its place, and now the wall is visible in section. I didn't even change the window family that I used. I assume it's a random glitch with that window or wall or something.
The option to create Wall section not showing up, only building section. |
Wed, Jan 23, 2013 at 3:16:46 PM
Earth and Wall cut patterns not showing in wall section... |
Thu, Jan 5, 2012 at 3:08:36 PM
Walls not showing up on section cuts |
Tue, Feb 7, 2012 at 2:52:55 PM
Wall type properties not showing in section Revit Architecture 2012 |
Fri, Jul 5, 2013 at 9:17:46 AM
Void extrusion not showing in section cut |
Thu, Jun 12, 2014 at 12:36:06 PM
Members: | 2022260 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
