44 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> curtain walls
Tue, Apr 23, 2013 at 5:23:56 AM | curtain walls
yoyo88
hi
i want to create a timber slat wall to go on the out side of a building. is it possible to create a crutian wall to get what i want if so any good links
thanks
Tue, Apr 23, 2013 at 5:28:24 AM | curtain walls
4 Stars: 203 Votes
Use a good texture to create that effect, also, you have that kind of texture / material in your materials tab.
Tue, Apr 23, 2013 at 5:31:50 AM | curtain walls
yoyo88
id like to have the see through effect as well though
Tue, Apr 23, 2013 at 7:42:32 AM | curtain walls
Not sure what you mean by timber slat wall.  Most walls, even walls that have surfaces like metal siding, are best done by using materials and not modeling the physical shape.  If the surface has voids all the way through it,  I would still probably use a wall with in-place void areas.
There are times where if it is not a wall, there are other options.  Like the image attached where I used a railing to create a fence.  Much better than a curtain wall for this image.
Wed, Apr 24, 2013 at 1:02:32 AM | curtain walls
yoyo88
this is what i want to create. railing may be the best way any suggestions on how to do it
Wed, Apr 24, 2013 at 7:30:52 AM | curtain walls
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Yes a railing is your best option for this.  Just create the profiles you want for your "rails" and create a balluster the size you need it to be.
Angled Curtain Walls - fillets and nested
Thu, Apr 23, 2009 at 5:42:47 PM
Curtain walls
Mon, Nov 7, 2011 at 10:28:33 AM
Curtain Walls
Wed, Apr 16, 2008 at 1:30:46 PM
curtain walls in legends
Tue, Feb 23, 2010 at 9:50:09 AM
14
solid walls transparent to curtain walls and railings in back..
Mon, Oct 29, 2012 at 7:34:26 AM
Page generation time: 0.8222
